Config help for a site [halfway done]
postwasabi
Postby postwasabi » 09 Oct 2016, 08:02
Hi, im trying to download max res images from this site https://e621.net/post/index/1/female%20solo using the following:
Regular site>follow all links>depth 2
Included: .*\/data\/[a-f0-9]{2}\/ and .*\/post\/index\/\d+\/
It works well, but EPF seems to get only the page links visible from the start address, so anything between pages 10 and third-to-last are skipped.
Re: Config help for a site [halfway done]
Postby Maxim » 10 Oct 2016, 13:01
Try using the following filters in the "Included URLs":
/post/index/\d+/
/data/[a-f0-9]{2}
Worked for me.
postwasabi
Postby postwasabi » 16 Oct 2016, 20:32
I tried your expressions like above and still doesn't work. Here is mine project settings: http://pastebin.com/spQhuHV0
I don't know if there is another setting that i'm missing.
Postby Maxim » 17 Oct 2016, 15:31
OK. First, make sure you have the most recent version of the program:
http://www.webimagedownloader.com/download/PictureFinderSetup.exe
Then download and run the this project:
projects/e621.net-search-female-solo.epr
(right-click the above project link and choose "Save link as..." menu item).
postwasabi
Postby postwasabi » 18 Oct 2016, 06:57
Now it's working perfectly =)
Many thanks for your awesome program and help!
Return to “Extreme Picture Finder”
