vbulletin forum thread
PP100
Post by PP100 » 03 Jul 2016, 14:11
I would like to extract all the pics from this thread but the settings I have tried have had little effect.
http://forum.bodybuilding.com/showthrea ... =148799213
It is a Vbulletin forum,
Please advise
Re: vbulletin forum thread
Post by Maxim » 04 Jul 2016, 12:35
OK, here is a template which works with any thread on this forum:
You can download it and create your projects with starting URLs like the one you provided. Or, if you need only this thread - open the template page, switch to the "Projects" tab and download the project for your thread.
If some images were not downloaded - let me know exactly what images and the thread page they were located on. I'll update the template to handle them too (if it's possible).
PP100
Post by PP100 » 08 Jul 2016, 22:36
I will have to upgrade to use that template. My version doesn't support them.
