Need help downloading from Imgur
Samson
Post by Samson » 30 May 2016, 17:58
Hey I got a small problem.I tried to download wallpapers from the imgur gallery http://imgur.com/gallery/zYdiP . But for some reason out of like 50 wallpapers it only downloads 10 and just stops as it thinks it has already downloaded them all. Tried it with different galleries too but same thing happens. Any ideas what's wrong? Also I have the latest version of the software
Re: Need help downloading from Imgur
Post by Maksym » 30 May 2016, 18:12
OK, I think I can create a template for these galleries, but I'll need more sample URL. Can you give me more? Preferably not only with JPGs, but other kind of images and videos.
Samson
Post by Samson » 30 May 2016, 19:05
Ok here's more sample galleries from imgur. I think most of them are in .jpg format so not sure where I can find a gallery that would contain images in different format. Thanks
http://imgur.com/gallery/DWWHf
http://imgur.com/gallery/g5Xef
http://imgur.com/gallery/Jqsdq
http://imgur.com/gallery/wWF2c
http://imgur.com/gallery/LzVdN
Post by Maksym » 31 May 2016, 12:50
OK, here is the imgur.com gallery template:
You can use it to create projects with as many gallery URLs in one project as you need - images from separate galleries will be saved into separate sub-folders.
Post by Maksym » 01 Jun 2016, 11:56
Template was updated for galleries with URLs like imgur.com/a/XXXXXX and imgur.com/r/XXXXXX
