I'm having trouble downloading images with EPF from a free site:
http://www.topheavy.com
After you click Enter, you're taken to the main page:
http://www.topheavy.com/thnewnew/main.php
Thanks!
Greg
trouble with topheavy.com
Re: trouble with topheavy.com
OK, this site should have worked with the default settings, but the problem is: it is protected from batch image downloaders like EPF, so you have to use the [ Delay between downloads ] option. Here, I created a template for this website:
So, first of all, download the most recent version of the program:
Then download and install the template from the above page and create new project with your starting address. Or you can download the project file from the "Projects" tab on the template page.
And make sure you use no more than 5 simultaneous connections to make the website think you're using browser.
Thanks a million, Maxim! Works awesome now.
You're welcome Greg!
