Hitomi.la
AstrYx1
Hitomi.la
Postby AstrYx1 » 09 May 2016, 06:50
I would like to know how to configure EPF to download images from Hitomi.la because sometimes the download button of the site doesn't work, specially with a big set.
here's an example:
https://hitomi.la/galleries/917245.html
Thanks for your help
Re: Hitomi.la
Postby Maxim » 09 May 2016, 16:14
Here is a project for you:
projects/hitomi.la-917245.exe
You can use it for any gallery on this website. You can even add several gallery URLs to one project - every gallery will be saved into its own sub-folder.
AstrYx1
Re: Hitomi.la
Postby AstrYx1 » 09 May 2016, 22:36
Thanks, amazing.
epfuser38
Re: Hitomi.la
Postby epfuser38 » 29 Sep 2016, 18:45
i have problems when i try download galleries from hitomi.la.
- pictured are scanned but not saved
example from log:
https://g.hitomi.la/galleries/981128/001.jpg socket error:11001
when i try open in web browser: "Could not locate remote server"
in fact target pictures are on adress beginning: "https://c.hitomi.la/galleries/981128/001.jpg" there is not "g.hitomi.la/..." but other letter
Few months ago all works - i think hitomi.la something changed and i am not able adjust project properties to work. But maybe could be problem on my PC
Even the template created by Maxim doesnt work now on my PC.
Can anyone help me?
thanks
Re: Hitomi.la
Postby Maxim » 30 Sep 2016, 12:38
OK, I updated the template, but it'll require more testing. They encoded the original image URL with JavaScript, so it's not that easy to get those images now:
http://www.webimagedownloader.com/templates/3-hitomi.la-gallery-template/
epfuser38
Re: Hitomi.la
Postby epfuser38 » 30 Sep 2016, 12:57
gallery URL for example what i posted is:
https://hitomi.la/galleries/981128.html
... but i have same problem with any gallery on hitomi.la now - few months ago was all OK
Re: Hitomi.la
Postby Maxim » 30 Sep 2016, 13:06
OK, try the updated template and let me know how did it go.
epfuser38
Re: Hitomi.la
Postby epfuser38 » 30 Sep 2016, 13:10
I just tried your new template on 3 diffrent galleries and it works great!
Thank you very much!
Re: Hitomi.la
Postby Maxim » 05 Oct 2016, 14:11
Return to “Extreme Picture Finder”
