Is it possible to use EPF to download from 8muses.com?
Mp70
Post by Mp70 » 28 Apr 2016, 19:56
I have been trying to use EPF to download some of the galleries on www.8muses.com but I can't seem to get it to work. Is there a way to do it? Thanks!
Here is a sample of their galleries:
https://www.8muses.com/album/nicole-hea ... he-wedding
Re: Is it possible to use EPF to download from 8muses.com?
Post by Maxim » 29 Apr 2016, 11:15
Here is the template for any album (or entire category) from this website:
Mp70
Post by Mp70 » 29 Apr 2016, 19:09
Awesome! Thanks guys, great support and a wonderful piece of software.
AstrYx1
Post by AstrYx1 » 01 May 2016, 23:18
Renaming FOLDERS...
Hi, I'm using the project and I have a question about it.
The project works amazing but I want to know if is it possible that EPF renames the folders for the title of the gallery for more than one gallery at the same time.
I changed the settings in "save sub-folders, and select the option: "Create a sub-folder for each starting address", so it works great downloading AND separating each artist or gallery by folder at the same time with this: 00001, 00002, 00003, etc. but I want to know if EPF have this automatic renaming feature for the folders and how to use it.
not sure if you need these two examples for the solution, but in case you do.
https://www.8muses.com/album/nicole-hea ... -honeymoon
and the result would be 2 folders called: The wedding and the other one: The honeymoon.
Post by Maxim » 02 May 2016, 09:35
Currently EPF can not use page title for folder names, but it has other nice options. I used "parent URL Regular Expression" like this:
RE: /album/([^/]+)/([^/]+)
Result: [#1]\[#2]
to have files saved in the following folders:
nicole-heat-comics\the-wedding
nicole-heat-comics\the-honeymoon
AstrYx1
Post by AstrYx1 » 02 May 2016, 17:19
Amazing it works great for me now. Thanks.
AstrYx1
Post by AstrYx1 » 11 Jun 2016, 00:29
Hi, I've been using the project and I've noticed that sometimes, when EPF download some sets that are 4 or 5 links away it saves them all in one folder. Not all of them, a few.
I have this settings:
Save
Sub-folders
/album/([^/]+)/([^/]+)/([^/]+)/([^/]+)
[#1]\[#2]\[#3]\[#4]
[#1]\[#2]\[#3]
[#1]\[#2]
and as you can see, I tried adding more than one RE, and it does download how i want it, but sometimes it fails and download some sets that are more than 3 or 4 links away in the same folder. i'm i missing something?
for example if i download 10 sets of the same album, 8 sets are where they belong and the other 2 are in 1 folder.
Post by Maxim » 11 Jun 2016, 19:03
I think I'll need an actual starting URL to test this. Can you give it to me?
AstrYx1
Post by AstrYx1 » 11 Jun 2016, 19:19
I want to download the sets without the need to go to the end of the links and copying them in EPF
i'm able to do it but some time it fails.
this is the album
https://www.8muses.com/album/renderotica-comics/3d-xxx
and I write in EPF, in included urls:
/renderotica-comics
It downloads the images, but it fails to save them in their respective folders, It saves them in one folder, these are the links that fail.
https://www.8muses.com/album/renderotic ... /chapter-1
https://www.8muses.com/album/renderotic ... /chapter-2
AstrYx1
Post by AstrYx1 » 11 Jun 2016, 19:37
here's an screenshot. it downloads well with the links: 3derotic but it fails with: 3d-xxx
