I've been trying to download images from the site for the past few weeks without any success.
Every time I want to download from the site, it downloads the entire site or just the main page images.
I want to download them in two ways:
By artist or keyword.
Examples:
url by artist:
http://www.hentai-foundry.com/pictures/ ... tonepretty
or
url by keyword: using funny
http://www.hentai-foundry.com/search/pi ... l&scraps=0
any suggestions???
Hentai Foundry
Re: Hentai Foundry
I almost forgot: Everytime you enter to the site, you have to click the HF logo image to enter to the galleries.
And as you can see the two galleries are different in the first one you enter by user, and in the second one, you enter by typing in the search criteria and changing the "All Fields" option to "Keywords" and click enter so you can reach to the exact gallery you want.
Probably the bold text is not important in this matter, but I write it only in case you need it to work better in the solution.
Re: Hentai Foundry
OK, here is the template to download all picture from any selected artist:
www.hentai-foundry.com - download all pictures from selected author
Re: Hentai Foundry
The problem that I have now is that when I try to adapt the artist template into another artist it doesn't download anything.
Here's what I did: using the artist, aka6
Starting address:
http://www.hentai-foundry.com/pictures/user/aka6
Excluded URLs:
Included URLs:
/aka6
and everything else is exactly the same. It doesn't download anything. I'm I missing something?, besides knowledge? XD
Thanks in advance, I appreciate your time.
Starting address:
Excluded URLs:
Included URLs:
/aka6
OK, here is the project for the artist:
projects/www.hentai-foundry.com-Coppertonepretty.exe
This one was easy. Since all URLs (pages and files) have the author name in it you can exclude everything by adding
to the "Filters -> Excluded URLs" and then add the author name to the "Filters -> Included URLs":
/Coppertonepretty
to make EPF scan only necessary URLs.
Re: Hentai Foundry
Just make sure you have "/" at the end of starting address and it will work just fine:
http://www.hentai-foundry.com/pictures/user/aka6/
Re: Hentai Foundry
Thanks Maxim Senpai you are amazing, it works great now.
