Ask EPF Support sankakucomplex.com
de2apandi
Post by de2apandi » 01 Feb 2016, 16:01
Hi Maxim is EPF support bacth download from sankakucomplex.com ?
If yes can you make project for this http://idol.sankakucomplex.com/?tags=lolita_cheng
Thanks you :)
Re: Ask EPF Support sankakucomplex.com
Post by Maksym » 02 Feb 2016, 15:26
Well, I created a project, but the site is protected from EPF-like programs. They do not let many simultaneous connections to go through. So use 2-3 (or maybe even 1 connection) with this project. If it won't help - increase the [ Delay between downloads ] to 5-7 seconds.
projects/idol.sankakucomplex.com-lolita_cheng.exe
de2apandi
Post by de2apandi » 02 Feb 2016, 15:48
OK thanks maxim
