Ideas
20th Century Idea
Ideas
Post by 20th Century Idea » 12 Jul 2015, 14:18
Here's a few ideas for the awesome devs.
1)The project properties dialog window can be longer to avoid the scroll bar on the left side to be necessary. 100 pixels isn't the end of the world to help users avoid from pulling the scroll bar up and down. It's a pain on a laptop.
2) When creating a new project while one is currently running, allow for an option that will hook-up the new project to be run after the current one. If a new project is created after that, move down the chain and hook that one up after. Essentially, automatically create a queue of projects. I'm thinking of a check box that will not be greyed-out if a project is currently running. If that current project is running and already has a queued project, fetch the next project and find out if that one has a queued up project. So on and so forth.
The alternative is let the user to through the trouble of going to the options and select the next project manually.
3) When entering the url generator dialog, the previous url is left in the text box. If a current url exists in the clipboard, paste it over the existing one. Perhaps leave the options as they are, but only replace that text box with the current url in the clipboard.
Re: Ideas
Post by Maksym » 12 Jul 2015, 20:04
Thank you very much for those! Adding to the to-do list!
