Hi Guys,
First wonderfull software, i really love it !
But i have one question, i would like to download images from a website but i would like to download them in sub-folders depending of their categories/URL.
For example :
The website : www.website.com
The images are stored under sub-categories like this : www.website.com/category1/ , www.website.com/category2/ , ....
So what i want is simple, download images in folders category1, category2, ....
How can i do ?
Thanks in advance !
Create sub-folders from URL
Re: Create sub-folders from URL
Well, it's quite easy. First of all, make sure you have the most recent version (the advanced sub-folders options are available only from 3.27):
Then, in the project properties select the "Save -> Sub-folders" section and check the "Use target file parent URL Regualr Expression" box. Then click the corresponding "Add..." button and enter the following:
Regular Expression: website\.com/([^/]+)/
Result: [#1]
Like this:
If you'll have problems with this - give me the real URL and I'll create a ready-to-use EPF project for you.
Result: [#1]
Like this:
