help, how to download
Re: help, how to download
thanks, work perfectly :), i just need setting proxy server on internet explorer, because EPF use login manual with IE.
Yes, that's right. EPF uses IE to execute "Manual login". So you need the same proxy in both EPF and IE.
another question :
if i change starting addres to http://pics77.blogspot.com/2011/07/chik ... tions.html,
it's not download picture in that page, but another picture on other link.
can you help
can you help
Yes, I think I can help, but I don't understand what are you trying to achieve. Do you want to download pictures ONLY from this page?
not only from this page, another page to, but with your setting only get around 300 pic, so i decide to download each page 1 by 1 if i can, so from your setting i change starting addresses, but can't download any picture
Well, the problem is definitely not in the settings. Here is the result I got with this project:
maxim, can you help me make setting for download from this page http://pics77.blogspot.com/2011/07/chik ... tions.html
from your setting earlier i download 3000 picture, but non of them from this page, the problem is my connection, so i use 1 simultaneous connection to download or do you have another way for bad connection. and the setting for that page and a couple page that can't download from your setting
Simply add the following filters to the "Included URLs":
^http://imgchili\.com/album/
^http://imgchili\.com/show/
