Image Search Results - Match Quality is Poor
AeonDistraction
Post by AeonDistraction » 16 Nov 2014, 16:43
This program used to be excellent with filtering search results based on specific keywords, not I am getting a bunch of junk results. Has something changed in the search algorithm over the years? Comparing the results to that of a Google search, there are major differences, as I would expect there to be, but completely unrelated results are coming up in my results in EPF. It''s borderline useless.
Re: Image Search Results - Match Quality is Poor
Post by Maksym » 16 Nov 2014, 18:21
Hmm. This is really strange... Because EPF actually uses Google Images search results... Which phrase returns unwanted results in EPF? Make sure you have the most recent version before you test:
