Girlsreleased.com
testauditgm
Girlsreleased.com
Post by testauditgm » 29 Oct 2014, 17:25
Hello.
I would thank the developers for their good job ;-)
BTW, i would like to download all the galleries of a certain model on https://www.girlsreleased.com
For example, I'd like to download all the galleries of this model : https://girlsreleased.com/#model/1188/Tiffany%20Taylor
I've tried several different method but cannot do my job.
Could someone help me ?
thanks.
Re: Girlsreleased.com
Post by Maksym » 30 Oct 2014, 13:19
Yeah, this one is actually tricky, but doable. Here is a template for you:
girlsreleased.com downloader
By the way, WHAT A GIRL! ;-)
You can use this template for both model pages with URLs like the one you provided and for single set URLs like:
https://girlsreleased.com/set/XXXXXX
And for the "sites" with URLs like:
https://girlsreleased.com/site/site-name.com
You have to use the most recent version of the program to make it all work:
If you need detailed instructions on how to use EPF templates - here is the tutorial:
How to install and use project templates/
Fluff546
Post by Fluff546 » 16 Jul 2015, 00:09
Thanks Maxim, you're the best!
lexus
Post by lexus » 20 Jan 2016, 18:58
This doesn't seem to be working anymore. Any ideas? I have tried several settings, and taken a look at the resources, but can not download any sets, keep getting a 404 error.
Post by Maksym » 21 Jan 2016, 13:44
Now this is kind of strange. It works perfectly now on all my test PCs...
Just in case - re-install EPF from this link and try again:
lexus
Post by lexus » 21 Jan 2016, 20:14
I'll re-install, and give it another try. Thanks
lexus
Post by lexus » 21 Jan 2016, 20:29
That did it, I must have had a corrupt file or something thanks!
psikarius
Post by psikarius » 25 Jun 2016, 20:07
hi. i have a girl with a lot of galleries.
here:
https://girlsreleased.com/#model/52/Lexa
but, when i download it only permits 16 galleries, and she has more than thirty (30). cuold you help me to download all her galleries please
Post by Maksym » 26 Jun 2016, 12:10
Check out my reply in this thread:
viewtopic.php?f=4&t=10481
