Regular expressions
Iluvatar
Regular expressions
Post by Iluvatar » 09 Oct 2014, 18:22
thank you for your fast help yesterday!
I have an additional question:
What regular expression engine do you use, and can I avoid links containing a string? (like, when it contains: "[IMG]" - don't match).
Thank's in advance
Re: Regular expressions
Post by Maksym » 10 Oct 2014, 10:06
You can read about Regular Expressions used in Extreme Picture Finder here:
http://www.exisoftware.com/picture_find ... sions.html
If you want to make Extreme Picture Finder skip some links - use [ Filters -> Excluded URLs ] section of the project properties. You can add as many Regular Expressions here as you need. In your case you can simply add
[IMG]
to make Extreme Picture Finder skip any URL containing "[IMG]".
de2apandi
Post by de2apandi » 08 Nov 2014, 03:22
Can regular expression tutorials coupled with examples and explanations website http more. It may be in the form of a PDF
Thank you.
