download from img chili
theguy22
Post by theguy22 » 28 Oct 2013, 02:53
I cant seem to download from picture host album
An example
The Album is located at:
http://picturehost.com/album/65bbca4097 ... 4566322344
Click on Picture
http://picturehost.org/show/27050/27050047_cute665.jpg
So once i click on a thumbnail. It takes me to picturehost.org not .com and i can see the photo
So the gallery is located on .com and the picture is located .org
How can i configure it? I can't seem to get it.
Re: download from img chili
Post by Maksym » 28 Oct 2013, 10:51
The starting URL doesn't have any images. And the "picturehost.org" domain name is "for sale"... Give me correct starting address and I'll try to help.
theguy22
Post by theguy22 » 28 Oct 2013, 12:22
It was just an example. I wasn't sure if i was allowed to write the real hosts.
Ok this is the page i was trying to download from It is NSFW
http://imgchili.com/album/65bbca4097ac2 ... 26d540c277
Post by Maksym » 28 Oct 2013, 12:35
Here is a template which allows to download all full-size images from any imgchili.net album:
Simply download and install this template and create a project with your starting address in the latest version of Extreme Picture Finder:
theguy22
Post by theguy22 » 29 Oct 2013, 02:58
wow it worked. you are so smart. i couldnt do it myself.
Thanks!!
westboy82
Post by westboy82 » 05 Feb 2016, 00:47
I have a similar issue:
I'm trying to get this photos in bulk:
http://adultphotosets.ru/rylskyart-maja-kembali/
but it point there:
http://imgchili.net/show/72903/*.jpg
How the configuration should go? Is it a TGP?
Tnx a lot!
Post by Maksym » 06 Feb 2016, 14:58
OK, here is a project I created using the above template:
http://www.webimagedownloader.com/templ ... ject/2289/
So, if you want to download other albums from this website - install the imgchili.net template from the address I gave in previous message. Here are the generic instructions how to install any Extreme Picture Finder template:
http://www.webimagedownloader.com/how-t ... templates/
