Control display features
lemstem
Post by lemstem » 02 May 2009, 18:11
I am creating displays for clients and want to control each display when it opens.
From my Index page, I can use javascript to control the new window that opens (height=800,width=800,scrollbars=1,menubar=0,resizable=1).
See my site: http://www.v-lens.com/index.htm and click one of the Sample Tour buttons.
How can I set the Extreme Thumbnail Generator defaults so the window always opens to these settings? I need to give the links to my clients so the code needs to be created automatically in each index page created by your software.
Re: Control display features
Post by Maksym » 03 May 2009, 21:33
I need some clarification. Do you want it to make so that when user clicks on a thumbnail image, a new window is opened with the following attributes:
nd this window must display a full-size image page. Right?
lemstem
Post by lemstem » 03 May 2009, 23:53
No, that is not my problem.
My clients will get this link to post on their own web page: http://www.v-lens.com/2009-04/sagebrush36514/
When they click on this link, each window should open with the parameters I described earlier.
Thank you for your quick reply.
Post by Maksym » 04 May 2009, 08:52
I think Extreme Thumbnail Generator has nothing to do with this. It can generate and upload galleries, but it's up to you to create a link that opens this gallery. And you can use any JavaScript window parameters in that link.
I see 2 ways to solve your problem.
1. Send links to your clients in HTML emails.
2. If you can send only plain text emails, then you can create a special page with links to galleries (with your parameters) and then send your clients link to that page.
lemstem
Post by lemstem » 04 May 2009, 23:45
Maxim,
Thank you for your reply.
Can't the gallery index.html be configured to open with certain display parameters?
I do understand that I can create javascript links but would like the process to be simpler for my clients.
Thanks,
Mel
Post by Maksym » 05 May 2009, 08:18
Well, you can re-size window using JavaScript in the onLoad event like this:
<body onLoad="window.resizeTo(800, 800)">
But I doubt you can hide window main menu after it was opened.
lemstem
Post by lemstem » 05 May 2009, 22:13
Thank you, Maxim.
Can I code this into the template?
Post by Maksym » 05 May 2009, 22:37
Yes, this is exactly what you need to do. Place this code into the template of the thumbnails page.
